The following tables, groups, and variables are supported in this MIB.
All tables and variables of this MIB are supported as read only. The comments here are abbreviated versions of the description in the RFC documentation.
| Table/Group | Supported Variables | Comments |
| pwMplsTable | pwIndex | This table controls MPLS-specific parameters when the PW is going to be carried over MPLS PSN. |
| pwMplsMplsType | This object is set by the operator to indicate the outer tunnel types, if existing. | |
| pwMplsTtl | This object is set by the operator to indicate the PW TTL value to be used on the PW shim label. | |
| pwMplsLocalLdpID | The LDP identifier of the LDP entity that creates this PW in the local node. | |
| pwMplsLocalLdpEntityIndex | The local node LDP Entity Index of the LDP entity creating this PW. | |
| pwMplsPeerLdpID | The peer LDP identifier of the LDP session. This object should return the value zero if LDP is not used or if the value is not yet known. | |
| pwMplsOutboundTable | All objects | This table reports and configures the current outbound MPLS tunnels (i.e., toward the PSN) or the physical interface in the case of a PW label only that carries the PW traffic. It also reports the current outer tunnel and LSP that forward the PW traffic. |
